You can also apply this to surrounding surfaces to prevent weld spatter from damaging machined surfaces. Or a thin coat of grease prevents weld spatter from damaging the machined surfaces.
Always remember. A weld will not join if the surface is contaminated.
If you can jam a nut on the remaining part of the bolt and don’t shake too much, you can spot weld through the hole in the nut and not hit anything else. I’ve only done it once myself.
Long overdue update on this…I have been very busy with college and work schedule.
I went ahead and put the pan etc back on, so far no leaks. Would like to thank everyone for the suggestions:) If it does start leaking I’ll give it another go.
