Brakes on a 98 silverado
replaced brake calipers master cyclinder an bleed the brakes an the pedal still goes to the floor. stiff when truck is not running an as soon as u start it they go to the floor
Do you have ABS, and did you bleed the ABS module? Did you bleed the rear brakes as well?
yes they r abs.i bleed the back brakes. did not no u had to bleed the abs module.an where is the abs module located at
Sounds like it could be the master cylinder has failed. If you pump the brakes do you get anything?
replaced the master cyclinder. both front calipers are new.
