I recently had my wheel hub and bearing replaced. The mechanic said I might hear a little noise with the brakes but they’d work. Turns out that noise is the Anti-lock braking system engaging every time I use the brakes. It happens when the car speed gets low, maybe 5-15 mph. Also, if I’m driving slow in a parking lot or something, and let off the gas, that change in speed sets the ABS system on too, without my foot being on the brake pedal.
I’ve also noticed sometimes when the weather is very cold, the ABS light will go on and the ABS brakes won’t work; just regular brakes.
Is this something that I’d be able to solve at home? Could I possibly bleed the brake lines to check for any air ( although braking seems fine ) , busted fuse for the system, anything else to check before asking the mechanic?
