I have been hearing my breaks squeal recently and I know that i need new brake pads. I only believe that it is my back breaks that are doing this though. Should I get both the front and rear break pads replaced at the same time?
Have the fronts been replaced before?? Usually the rears are replaced once for every 2-3 times the fronts are replaced.
As for replacing the fronts also…Just have them checked. There’s no need to replace the pads if they are still fine.
Your mechanic can measure the pads to see how much thickness remains. They only have to be replaced when they become too thin.
