Brake master cylinder seals for Chinese ev trike
I have a 07 zap xebra truck. The seal at the rear of the master cylinder has given up and leaks fluid into the cab floor. I removed the maser cylinder and have disassembled. Problem is the there are no parts available for these guys. I’ve measured the rear seal and it is 20mm OD and 13mm ID. It has u shape profile. Where can I find such a seal? Is there a place to cross reference the dimensions of such parts?
Thanks
This is my go-to supplier for unique parts/components.
I’ll second Testor’s advice to hit McMaster Carr.
Be sure and get the right material (EPDM rubber) for the seal. Brake fluid eats nitrile rubber. Test the seal you bought in a small glass with brake fluid in it overnight. It is swells or melts - wrong material.
Thanks for the advice. Does that type of seal have a name? Cup, follower, wiper etc..
Also following the link to mcmaster I wasn’t able to locate any seals in epdm
That would be a U-shaped cup seal.
My other possible option is to swap the master cylinder out with one from another vehicle. What are the ramifications of going from a 3/4 bore up to a 7/8( which seems like about the smallest that put on cars). It is dual port and it has no vacuum assist.
The larger bore would increase the pedal effort.
