Speaking of bleeding brakes, is it still acceptable/possible to gravity bleed today’s brake lines?
As far as I know yes/yes. I haven’t actually done it on anything newer than a 2002 Mazda Protege.
Depends on the ABS system. Some allow gravity bleeding while others require an ABS scanner to position the valves to their home position in order to do any kind of brake bleeding
That’s what I was worried about. I do have ABS.
Don’t know if if it’s possible with you car but if it is there is nothing wrong with it. I always bleed brakes with the gravity method.
