Black smoke and fuel smell
I have a Fiat Punto mk2 from 2004 that has a petroleum engine 1.2L 60HP.
I have had an intermittent ignition coil problem where the car would start shaking when idle and when the engine is hot (when the fans start) for a brief moment and stops when I accelerate. The problem went unfixed for a month or two.
Last week I changed the faulty ignition coil and changed the spark plugs at the same time.
The same night I started smelling petroleum inside the car and from the tailpipe. I suspected loose sparks plugs so I removed them and found them fouled with carbon, I cleaned them, checked the gap again, put them back and made sure they are perfectly tight. But the problem remained.
The next day, the car started producing black smoke but not very visible. When the engine is idle, it is smalls puffs of black smoke that happen at regular intervals (maybe every half a second or a second) and in between the exhaust is clear. When I accelerate, there is a big puff of smoke and then the smoke stops completely until the car idles again or until I decelerate a lot and accelerate again.
When the car produces small puffs of black smoke, the engine “sputters” (is that the right word ?) at the same rate and then it seems like it wants to accelerate or stabilize and then it starts “sputtering” again but there are no loud noises or any alarming ones.
I also noticed that the acceleration is not as smooth, the car is hard to accelerate, and sometimes, when idle, the rpm goes high and stays high until I press the gas pedal and than remove my foot (while being in neutral). Most of the time, the rpm returns to normal but rarely it won’t until I turn off and on the engine or until I drive for some distance.
The car also threw a bad O2 sensor error code and although I had it changed 9 months ago, I went ahead and changed it again. When I removed the old one, it was fouled with a lot of carbon.
After changing the O2 sensor, the smoke stopped for 2 days but the fuel smell remained. Now the black smoke is back again and there are no error codes at all.
There is also a strong gas smell in the oil dip.
Is it possible that the new spark plugs are faulty ? It also came to my mind that I haven’t changed the oil for 14 000 kilometers. Could this be the issue ? Honestly, I have no clue where to go from here, all I know is I have a rich fuel mixture and it could be anything but without codes it is so hard to diagnose. I’m even thinking the catalytic converter since the car has a mileage of about 200 000 kilometers.
Any help would be appreciated.
It seems you should first do a complete service of the car - change the oil, maybe replace the air filter, put some cleaner in the fuel tank to clean the fuel injection system, etc. You are getting too much fuel to the cylinders. Has your fuel use gone up a lot?
You might consider a problem with the fuel pressure regulator as that can cause fouled plugs/poor running/etc. Another potential cause for running too rich is a clogged catalytic converter. That might be especially true considering the current problems. The substrate in the converter can get partially clogged and that in turn can lead to a rich condition.
I tend to think any clogged converter problem would be the symptom rather than the cause of this predicament so I would suggest looking at the fuel pressure regulator first. This is what it looks like. There is a diaphragm inside that can rupture and feed raw fuel into the intake manifold.
