Belt Tensioner, Help!
db, originally I tried some epoxy on the fuel pump, as it had obvious stress cracks on the top. That initially worked, then the leak slowly returned. So I replaced the pump entirely. What a fiasco, smelled like gas for days. Unfortunately, I don’t have a lift so did it all with the car on ramps and crawling under it. But in the end all is well, at least with that. Next up, tie rods. Thanks.
