both have stopped working, bulbs seem to be fine, is there a fuse for the back up lights? 2002 Nissan frontier truck
Yes, there is a fuse. Check your Owner’s Manual for the location of this fuse, which probably serves some other electrical parts as well as the back-up lights.
If the fuse turns out to be okay, then I would suspect the back-up light switch, which may be located on the transmission.
Yes, there’s a fuse. Check your owner’s manual. There’s also a switch to activate the back up lights.
mcparadise–Do the two of us have mental telepathy?
If you check the times that our two posts were posted, we were apparently thinking the same thoughts at the same time, and we even used almost the same words.
Spooky!
