Got an AWD vue with worn carrier bearing. Does driveshaft turn during typical, dry pavement use? Seller said it vibrated when driven. Always? Or when AWD kicks in? I removed shaft today. Yes, it has a very sloppy rubber bushed bearing. I might replace bearing and install driveshaft, or maybe not.
Why not just fix it right, and get it over with?
https://www.rockauto.com/en/moreinfo.php?pk=8340552&cc=1428746&jsn=322
