What transmission fluid is equivalent to
Type A (1959 Dodge owner’s manual)
LubLine.com sells Type A and also says either Dexron II or III meets Type A specs. LubLine is a wholesaler, so getting Type A may require you to buy much more than you want.
Pennzoil.com doesn’t mention Type A at all, presumably because there is little market for it.
Dextron, Dextron II, or Mercon will work. See the attached link.
the manual requires no fluid.re read your post.makes sense to me.
answer wood pulp.(TYPE tree A bark-7866)
It’s Dexron, not Dextron.
