Auto repair- too expensive
Simple!
You go into a parts store, and tell them you want brake components that meets/exceeds the manufacturers specifications.
The brand doesn’t matter.
Because the brake components aren’t made by the vehicle manufacturer. But instead supplied by a brake component vendor.
Between .008" and .010". Most rotors have very little wear but some sports cars use a brake pad that wears the rotors .030 to .040", those usually can only be machined once.
If I lived in the rust belt and only worked on cars that are 10 to 20 years old, I would be replacing a lot of rotors but I can’t in good conscience discard brake rotors from a car that is 18 months old with .090" of material above the minimum specs.
OK, few years back, off I went to AdvanceAutoParts and they pushed Wagner semi-metalics to me as “better than OEM”… which wore much faster than OEM with quite decent original rotors I had.
the next set I bought was Bendix “organic” from some internet source, was really happy with these.
I thought you possess some “secret/sacred knowledge” on this :slight_smile:
We turn drums and rotors. And when I had my own place we turned them too. I can’t in good conscience sell a new rotor when the old one is still perfectly serviceable after being resurfaced. It takes 12 minutes to do a rotor, but while the lathe is cutting the tech will be cleaning and lubing the calipers, cleaning and adjusting the rears, changing fluid, etc. It really only adds minutes to the job, providing the last guy cleaned the grease off the lathe and hung the cones back where they belong.
Drums and rotors are expensive. Not all of them, but a quality rotor for a F250 Super Duty or even a Lexus can top $150. Resurfacing them for $30 each is in the best interest of the customer.
It’s been my experience that turning a rotor or drum in house often results in higher quality than some of the “white box” iron out there. I can’t remember a time when turning a rotor caused a comeback.
If I lived in a rust belt state I would imagine things might be different though.
For me, brake work is all about saving money, $20 for new pads versus $150-350 to have it done professionally is a significant difference.
Actually, for me, doing the work is always about saving money. I’m cheap like that.
There are 3 reasons I fix my own car when possible.
  1. I can, most of the time.
  2. It is less expensive.
  3. Most things I can do when it fits my schedule.
Sorry Whitey, I don’t know why the site made the whole quote yours, the first papgraph is George’s
I agree.
That price sounds quite low
If you don’t mind me asking, are you buying store brand non-premium brake pads?
RockAuto, 2012 Altima, Beck/Arnley
OEM material: $21 for rear, $25 for front
Ceramic: $24 for rear, $27 for front
quite in ballpark…
Centric ceramic is half the price ($12/$14), I’m using them now and they are OK for ~15K miles
Thank you, but my question was directed at Whitey
I’m kinda interested to hear @Whitey selection too
If a job is done correctly but the price seems high I soon forget the price. However, if a job is not done right, no matter how cheap the price, I don’t forget it.i had to watch my pennies when we were starting out. Even then, it was cheaper in the long run to pay more for a quality job.
@Tester knows the name of that car repair price estimate website. Tester … 'lil help for the OP?
Here’s the site.
You mentioned above as I recall that they claimed to do more than just replace the front pads. $350 does seem a little pricey if that’s all they did. Some dealership shops will do an overall look-see at the car, looking for upcoming trouble spots, look for broken cv and steering boots, top off fluids, stuff like that, and charge a fixed fee for that. Maybe that’s what the extra $150 is for. I’ve always held to the opinion that if I’m charged for something that I don’t understand, to ask what it is for from the person charging me. Suggest you go back to the dealership and ask. Worse they can say is: It’s our policy. Best case, maybe they’ll realize they made a mistake and they’ll give you a $150 credit toward your next service. I sense you are sort of new to car ownership and repair and maintenance costs. If so, you’d serve yourself well to become familiar with the book “Popular Mechanics Complete Car Care”.
I would be wary of a website offering repair estimates that then collects a commission from the shops to which it refers customers.
Yes, and they were actually $17 plus tax at Advance.
Thanks
I was merely curious
The downside is they only last a month…
(Kidding…)
:slight_smile:
Actually, it had been several years since my last set of pads, so I was sure they were worn out, but I discovered they lasted pretty well. I changed them out anyway, because half the job was half done already by then.
