Battery died and couldn’t unlock the trunk to get at the battery. Key’s also didn’t work in the trunk lock. Is there a battery terminal in the engine compartment? Many people think one exists but none have been able to find it.
If there are battery terminals under the hood, I can guarantee that the Owner’s Manual will display a small graphic showing the location of those terminals. All this should require on your part is opening the glove compartment and spending a few minutes reading the relevant section of the manual.
If you don’t have an Owner’s Manual, this just one example of why you need to obtain one.
E-bay is a good source for manuals.
