Chrysler Pacifica 2017 seems like it’s about to stall?
Just noticed that the van is idling weird. If I am not moving, it goes and almost stalls, then RPMs pick back up. It goes in cycles. It doesn’t happen all the time, but happens enough that I am getting concerned. As this is happening the voltage is fluctuating when I watch the gauge. ~14v down to ~10 (almost stall), then back up, then back down, etc…
Not sure if it is related, but when I press the ignition start, the car start fine, but it’s not as ‘clean’ of a start as a brand new car. Not bad by any means though. It has never not started.
Any ideas of what could be the problem before I bring to a mechanic? Any ‘known’ issues with this on Pacifica’s?
I’m the original owner and have generally maintained it.
Year - 2017
Make/Model - Chrysler Pacifica
Mileage - 48k
Engine size - 6 cylinder
Transmission Type - Automatic
Thanks
