so what is the difficulty factor for changing out the heater core?? any tricks other than paying the pro!! so how much will that be??
Are you sure it is antifreeze and not water from the AC drain? This one would be easier to deal with!
yep it’s pink liquid from a grey carpet
It should be $495 or less if you’re not too unlucky. It should be $100 if you do it right. If you can see the hoses, you can change it. I’m hoping that GM is like an 85 Cadillac where you pull off a panel and are staring at the heater core under the dash. You should have to get the hoses from under the hood.
