Another wheels stuck to hub with a twist
Thought I’d seen it all and then this. Trying to track down a persistent rattling sound over bumps with my 2018 F150. Sure sounded like it was coming from the front and the chassis ears weren’t helping so time to do a little deeper diving…and check things out while “in there”.
Of course the wheel is apparently welded to the hub. But the reason was not just corrosion around the hub centric ring. After some penetrating oil soaking and repeated pounding from the back side, the first wheel came loose. The entire back side of the wheel interface and hub face were coated in some kind of compound. It sure seemed like someone had used an entire can of anti-seize on it. But it was hard, much harder than I’ve ever seen anti-seize get. And it was tough to remove. I ended up using a sander because the wire wheel was not getting anywhere. The rotors had that anti-corrosion coating and some of it was peeling off with whatever was slathered onto the wheel and hub. This stuff had some stickshun to it (my word :))
There was nothing on the studs, thankfully. All the wheels were the same. And thankfully, I got them all loose and cleaned up before finding myself on the side of the road trying to change one of them.
Once ground off, it sure seemed like anti-seize dust. Anyone ever seen anything like this before? Those wheels were stuck big time. And the hubs were rusty but not to an insane degree where they shouldn’t have come off with some minor persuasion.
The saving grace was I found the source of the rattle- by accident. Contacted the rear shock while persuading the wheel to give up the challenge, and it rattled. The outer, upper dust shield rattled against the shock body. Strangely, the shocks seem fine. Just like the inner spacer or whatever they use to keep the dust shield off the body was gone. They are KYB and look fairly new… and both shocks do the same thing…
I have not seen anti-seize turn to dust like that, though I have had wheels stick fast from plain corrosion around the hub. A thin smear on the hub face only, kept well away from the studs, has worked for me since. Glad the rattle turned out to be the shock shield rather than something worse.
In my experience, KYB isn’t what it used to be
In fact, I’ve seen several well-known brands slipping in quality the last few years . . . at least it seems that way to me
And you’re one of the few people besides me that I’ve “encountered” . . . hard to encounter someone you’ve literally never seen and heard . . . who actually use chassis ears. Sure, there are some times when they’re not leading me to the cause of the problem, but they’ve usually nailed it or at least eliminated many things and gotten me that much closer
Although there doesn’t seem to be anything fundamentally wrong with the shocks, I am replacing them. If the dust shields are rattling, the rest can’t be far behind.
When looking for replacements, I found the OEM KYBs available but in reading the comments, found at least one person that had exactly the same problem. Within a fairly short time, they started rattling. So I started looking at alternatives. I liked the Bilsteins but was concerned reading the monoshock design results in a more controlled, but stiffer suspension. After a lot of looking around at various discussion groups and feedback comments, I decided to take a chance on them. One benefit, they have a non-metallic bellows to protect the arm so that will never rattle :wink:
The chassis ears have paid for themselves numerous times already. The first time happened when I could have sworn a left front hub was going bad. All the symptoms and the apparent source of the noise pointed to the left hub. Turned out to be the right one after listening with the ears. The only way they could be better is if they also had a pinhole camera in each one :heart_eyes:
Sounds are very difficult to nail down the origin. In this case, I was convinced it was in the front and, after ruling out the usual suspects, that it was something like partially engaged locking hubs- these are known for vacuum check valve failure leading to partially engaged hubs that rattle over bumps. I went through all the other possible suspects; heat shields, guards, suspension parts etc with no joy. Like you said, elimination of sources is half the battle. They may not have found this problem but they helped rule out a lot of the suspects…
I went with them on our '95 Suburban, they worked great. Only issue was compressing one of them while installing them in my garage. But I did, by hand, so that could have causes very little added stiffness to the Sub.
