Annoying sound
hi
i have a grinding sound comes from the front of my car when the speed reaches 60 miles,what can cause this sound.also i have a poping sound when putting the gear in reverse is that related?
thanks
A grinding sound? That doesnt sound good but I think we need more info here. A pop sound when going into reverse could be so many things such as the exhaust pipe or hangers hitting something… a loose driveshaft nut… Do the experiment while stopped put your E-brake on and then open the door and hang out of the car with your foot on the brake put your car into drive and reverse over and over to recreate the noise and see if you can narrow the noise down…
