-1993 Toyota Camry LE
- 4 Cylinder / Automatic w/277,500 mostly trouble-free miles
OK, I’ll give this a try. Both my independent Shop with over 35 years combined experience between the two techs
and the local Toyota Dealer can’t figure this one out.
Start the Cold Engine in cool (55F) Weather and the fast idle goes up to approx. 1100rpm while it warms up. (Normal)
After the Engine Coolant Temp reaches approx. 1/4 (about 2 minutes) the Engine Idle slows to approx. 900rpm. (Normal)
Further idling after 4 minutes; the engine idle will slow to between 450/600rpm and starts “surging” and idling very erratic. (NOT Normal)
It won’t stall, but comes very close to it and idles very rough and continuously surges at very low rpm like it’s starving for Air or Fuel.
If I drive it and get the Engine Coolant Temp. up to approx. 1/2 (Normal) it will run smoothly until I slow down to an idle again, like at a stop light.
Putting the Transmission in Neutral or Park has very little effect.
When the engaged Transmission load is taken off the Engine, it idles a little faster @ 600rpm, but still surges.
NO “Check Engine” light ever comes on and the ind. shop (or Dealer) cannot read any OBD Codes
What has been done so far:
Spark Plugs and Plug Wires have been replaced
Airbox and Filter Checked (OK)
Throttle Body/Plate and TB Interior was Cleaned
Fuel Pressure was checked (OK)
Fuel Filter was checked (OK)
Dealer tech. said ‘maybe a clogged EGR but you have to replace the IACV first to be sure’.
I followed their X-pensive suggestion and paid the $98 “Diagnosis” Bill which I now regret.
I was skeptical of this "Replace the more expensive IACV first and then try the less expensive EGR so I had the EGR CLEANED first — It was dirty/carbon residue on the internal Valve Seat so the EGR Valve was replaced to be sure.
Idle Air Control Valve (a $320 part !) was replaced
No difference even after BOTH IACV and EGR were replaced. — Disappointing…
EGR Vacuum Hoses were all Checked for leakage (OK)
EGR Metal Tube was checked for Clogging (OK)
Chevron “Techron”, Lucas Fuel Injector Cleaner, and ‘Sea-Foam’ have been tried as additives / cleaning agents
with just a slight improvement but still Idles very Rough @ approx. 500~600 rpm.
What could be causing this ?
Are there any other Sensors which could be giving false input to the ECU to cause this Idle problem ?
So far I’m out over $800 and the problem isn’t solved…
Thank you in advance for any suggestions.
david
