Show 1038 about two weeks ago had a caller with probles with a '95 Nissan Altima distributor (the car would stall). I had the same car and the same problem. The issue is the oil o-ring that goes in the linkage between the camshaft and the distributor. When the o-ring is worn, the optical encoder inside the distributor gets oil and malfunction. The o-ring is $5 at the dealer, the optical encoder can be cleaned with electrical connector cleaner. Since I changed the o-ring the car has been fine for 50k after.
Related topics
| 1995 Nissan Altima Stalls | 8 | 2963 | March 12, 2012 | |
| 04 Altima Chugging/jerking at any speed | 1 | 968 | June 17, 2010 | |
| 1995 Altima Chugalug edition | 3 | 551 | July 29, 2009 | |
| Nissan altima engine rings | 5 | 1159 | September 27, 2010 | |
| Stalling, otherwise running smooth | 10 | 4698 | November 23, 2011 |
