I have a 2000 Corolla CE with 48k miles that I bought 2 months ago. I took it in for an alignment and balance because it was pulling to one side and the steering shakes slightly at 70mph.
The before measurements was this:
Left Front:
Camber: 0.0
Caster: 1.2
Toe: 0.17
Right Front:
Camber: -0.7
Caster: 1.6
Toe: 0.28
Front Total Toe: 0.45
Steer Ahead: -0.06
Rear Left:
Camber: -1.0
Toe: 0.50
Rear Right:
Camber -0.7
Toe:-0.04
Rear Total Toe: 0.46
Thrust Angel: 0.27
The after measurements was this:
Left Front:
Camber: 0.1
Caster: 1.2
Toe: 0.08
Right Front:
Camber: -0.7
Caster: 1.5
Toe: 0.07
Front Total Toe: 0.14
Steer Ahead: 0.01
Rear Left:
Camber: -0.9
Toe: 0.22
Rear Right:
Camber -0.7
Toe:-0.22
Rear Total Toe: 0.44
Thrust Angel: 0.00
They said that the alignment was so frozen solid (I guess it had rust) that they couldn’t get it off without using the heat weld gun. They also used a Hunter Force Balancer to balance all 4 wheels. They told me the front 2 tires was in bad condition (even though I got them new 3 months ago) so they switched the ones from the back to the front. They also told me my struts were going to go bad soon.
Do these measurements sound right? I think my struts are good, when going over a bump, I can’t feel anything and I can hear the “gas shocks” working perfectly. Plus the bounce test I did on the struts were just fine.
I travel on some awful roads with full of potholes…how long can I expect this alignment to last?
(Btw, I have not tested the alignment on the highway yet, I will do that tomm morning).
