The air conditioner in my 2002 Thunderbird intermittently puts out HOT AIR.  The A/C light remains on and the compressor has been checked and is full and working OK.  The dealer had me check the control module  by pushing the 2nd & 3rd buttons together following by the automatic button.  It’s supposed to give a code describing what’s wrong, but it only resets the temperature to 75 degrees.  I found a site on www.consumerguideauto that says this car’s A/C may not work properly due to a bad control head module, but Ford Service says it can’t be that because there would have been a “code” when I did the above reset.  I did take it to Ford when it was acting up, but they couldn’t figure it out.
 Any ideas what could be causing this problem and how to correct it?
I hate getting nothing when I go to a dealer. The module should be changed anyway with the price they charge for those cars. A malfunctioning computer won’t always give a code.
