Aftermarket Fog Lights wire question
Do I get a ’ SOLVED ’ sticker?
Look at the relay base. Attach pin 30 and 85 to a fused circuit, I suggest one that is marked ACCESSORY. Connect pin 87 to the lights and 86 to one side of a switch and attach a ground to the other side of the switch. Grounding pin 86 will connect pin 30 to 87. Pin 87a is the default position for the relay and is not needed and there may not even be a pin there.
https://www.google.com/search?q=MB141967&rlz=1C1CHBF_enUS786US786&tbm=isch&source=iu&ictx=1&fir=VM-0L_qyYKcdM%253A%252CoR-5jhZ9vZmydM%252C&usg=__bQdjiktSqPv5NMpES20-3qFOV20%3D&sa=X&ved=0ahUKEwjsrJS6v6TaAhVStlMKHQa1BcoQ9QEIOzAD#imgdii=RWF08D6WPcEzxM:&imgrc=hArLj97MPs2uhM:
I found this schematic but also found that your relay may not have the generic numbers on it.
And now I find this
My instructions were for the NEGATIVE trigger version here. It sounds very B-O-R-I-N-G.
