My brother has accidentally poured a quart of transmission fluid int his coolant reservoir and now the car is overheating. I am wondering if flushing the radiator would do the trick or if any other major problems can incur due to this mishap
Yes, you need to flush that stuff out. A whole quart? I hope it hasn’t coated the inside of the cooling jackets. A chemical flush may be required to get all that oil out.
Ouch. The oil/water emulsion may form a gooey mess that will be difficult to flush out. Your water pump may be trying to pump something that looks like whipped cream. The good news is that it is not uncommon for transmission fluid to get into radiators. It happens when integrated transmission coolers start to leak, so there may be tips on the internet for flushing it out.
After checking Google for tips, I would first try flushing it out with lots of distilled water, and perhaps some commercial radiator flush. Those should not damage the system and won’t make it worse. Good luck.
If that does not work, I would suggest mixing some coolant/water/hydraulic fluid in a jar and see what forms. Then try different solvents (e.g. different kinds of alcohol) to see what will dissolve the gunk.
The concern here is that there are various plastic parts, hoses, O-rings, and gaskets in your cooling system that may have chemical compatibility issues with anything you put in there, so you don’t want to pour in anything that does not help and might harm. Your mechanic and maybe even the manufacturer probably won’t be able to tell you with confidence what solvents might help or hurt.
No big deal, just get the cooling system flushed. The trans fluid wont hurt any gaskets or the water pump in any way, but I would get it out of there as soon as possible.
transman
P.S. How in the world do you mistake ATF for coolant???
I put tranny fluid in my rad today, I had old oil in a coolant container that was with my unused jugs of oil and coolant. Never started it and after I realized what I did I drained my fluid and removed all my coolant hoses and flushed it twice with my hose. Bought a coolant cleaner and ran that through the car idling for 15 min with heat on then flushed that, then ran it again with just water for 10 more minutes and flushed. Took my reservoir off and rinsed it, then put coolant in!! I still notice some residual oil floating on top of my coolant put soak it up with paper towel, but my car does run normally and stays cool!! Hope doing this procedure does the trick
