AC problems
Sadly I own a 2010 Toyota Venza. For about 3 months(since May) I have been having problems with the air conditioner and front defroster. It works intermittently. Sometimes it will work for 3 days straight. Sometimes it will stop working while driving(it will blow hot air), but most of the time if I am driving and it works it will keep working for the whole ride. If I need to restart the car after a short stop it tends to fail, and then the next morning is a crap shoot. It seems to work better when it is hot out, but not always. I had a front end collision in November, and had the condenser replaced and the system recharged. The defrost worked fine all through the winter. Since May I have had the system recharged 2 times. the second time with dye in it (no leak). I was told to change the condenser valve (150.00), and then I was told that was not the problem, and that I needed to change the compressor ($2,000.00 for the part alone). The compressor seems to work. Any ideas?
I’d try another place, especially if this one isn’t an air-conditioning specialist. If the system has needed to be recharged twice, then you do have a leak.
Thanks.
