Abs tcc
Hey guys i am having these codes pop up abs c1233. C1276 c1282
C1293 c1284 c1284 c1287 c1288 and rss c0691 can any one please help me figure out what’s wrong with my car thank you in advance.
In the order that you listed them:
Right front wheel circuit open/shorted
Brake light circuit short
Yaw rate sensor bias malfunction
Code 1291/1292 set in current or previous ignition cycle (1291/2 being open brake lamp switch contacts during deceleration/when ABS was required)
Lateral accelerator bias malfunction ( you listed this one twice? )
Steering sensor rate malfuction
Steering wheel position sensor
Damper Control Relay Circuit Range error
With all those together it sounds like you come in line with the following TSB:
Vehicles with Multiple DTCs C1282 , C1283 , C1284 , C1285 , C1287 , C1288 - kw ABS accelerate aggressive brake calibration diagnostics DTC EBTCM electrical engage ICCS incorrect performance sensor
Vehicles with Multiple DTC C1282, C1283, C1284, C1285, C1287, C1288
The following diagnosis might be helpful if the vehicle exhibits the described symptoms in the PI.
Condition/Concern:
Multiple Stabilitrak/Precision Control Codes such as C1282, C1283, C1284, C1285, C1287 and C1288 exist on Delphi Bosch 5.0 or 5.3 systems. The range of codes may not identically match what is listed above, but if there is a trend in which codes simultaneously exist for the SWPS, Yaw Sensor, and Lateral Accelerometer, the information in this PI is applicable.
PROBABLE CAUSE: Loss of 5 volt reference or ground on circuits 1337 or 1338. It is unlikely to be a sensor issue in this circumstance, as the likelihood of having three sensors simultaneously fail is quite low. The common factor in this instance is the fact that the 5 volt reference and ground are shared for all three sensors.
Recommendation/Instructions:
You can verify this by taking a snap shot of the condition, and looking at the SWPS inputs, yaw rate sensor input, and the lateral accelerometer input. If review of these three inputs finds the voltage is dropping low/erratic, inspect circuits 1337 and 1338. Check all connectors, splices and pass-throughs between the EBTCM and sensors. Replacing any of the sensors or checking for a loose yaw sensor will most likely not repair the vehicle. In instances in which individual codes occur, use existing diagnostics. With regards to steering wheel position sensors, the Delphi-Bosch 5.3 system inputs are listed as Dual Analog SWPS Input A and Dual Analog Input B. These two inputs range from 0 to 5 volts. The Delphi-Bosch 5.0 system inputs are listed as Digital SWPS Phase A, Digital SWPS Phase B, and Analog Steering Wheel Position. The analog input might be the best input to track on the 5.0 system as it will be more obvious if the voltage is dropping out.
The yaw sensor also have a voltage range of 0 to approximately 5 volts and is at 2.5 volts at 0 degrees yaw. The lateral accelerometer has a voltage range of 0 to approximately 5 volts and is also at 2.5 volts when no g force is detected.
Please follow this diagnosis process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed. If these steps do not resolve the condition, please contact GM TAC for further diagnostic assistance.
Models:
(1997-2004 Cadillac Seville ) and (1997-02 Cadillac Eldorado) and (1997-05 Buick Park Avenue 2000-05 Buick LeSabre 2000-05 Pontiac Bonneville 1997-05 Cadillac Deville 2001Oldsmobile Aurora)
