When the a/c is on, it smells like antifreeze coolant and has a fishy/musty smell. No leaks in the right floor board. The a/c has a hard time cooling and has excessive evaporator drainage. We’re thinking the fishy/musty smell may be the heater core, but the coolant has stumped us. We replaced a bad radiator cap after it leaked 6 months ago. Oil also seems to be disappearing. There are no oil stains on the ground and no smoking.
Related topics
| Pretty sure heater core is leaking. Should I check anything before tearing out dash to replace it? | 20 | 10417 | August 17, 2022 | |
| Antifreeze smell coming out of vents when i run the AC | 12 | 114328 | December 14, 2019 | |
| Smelling antifreeze when I run heat | 15 | 140633 | March 3, 2019 | |
| Antifreeze smell | 9 | 5070 | March 13, 2009 | |
| Smelly AC | 1 | 417 | August 7, 2007 |
