Hey Guys!
Greetings from the midwest!
I have a 99’ Sebring that is having problems shifting in and out of gear; jumping because of the incorrect shifting. Bought it used a year ago , RPM meter only works intermittently. I have that it could be an easy-fix output tranny sensor , I just want to corroborate that.
Thanks in advance!
Heres the codes:
P 0140 02 sensor circuit
No activity bank 1 sensor 2
PO 733 gear 3 incorrect ratio
P 0760 shift solenoid C malf.
P 07600 transmission control system malfunctions
P 0305 cylinders 5 misfire
Which of these should cause this problem?
Thanks guys in advance
