just bought the car took it to the tire shop and as useual they want to change the tie rod ends inner and outter, both hub bearings,and ball joints for a grand total of 812 bucks.now im wondering both tires will move left to right but not up and down when a bearing goes out wont it make some kind of noise ,a roaring cause mine doesnt do that, there is quite a bit of slack in the tire left to right so im going to replace both inner and outter tie rods my self. is this a job i can do i know i need a special tool for the inner,anything else i need to know ?? thanks guys for your help
Most times, you need a special long socket. It costs over $100 sometimes. Sometimes there is no noise when something wears out. Wheel bearings are the silent kind of worn out.
