Gentlemen & ladies too, I have a leak which has developed between the bell housing & block on a 4 liter v6. The fluid seems to be oily, clear,and evaporates like water but leaves hardly any stain. The leak looks to be coming from a bolt that holds a elec. wire of some sort which is shielded which attaches at the split between the housing & block. I’m wondering if anyone has had or seen this before ? spyder Burleson,Tx
spyder
1
Check your coolant level
Related topics
| Oil leak | 6 | 2274 | May 24, 2015 | |
| Coolant leak in 94 ford explorer | 2 | 511 | January 9, 2008 | |
| Ford oil vent leak? | 2 | 517 | October 4, 2008 | |
| What is this? And would it leak oil? | 9 | 830 | September 10, 2022 | |
| Coolant Housing Outlet | 0 | 313 | February 10, 2011 |
