My 98 Camry LE experiences random cold stall. When it happens, I can get it to start by reving up the RPM’s. It doesn’t stall after it finally starts and doesn’t stall at stops.
The engine in your car uses a cold-start injector. This is mounted on the intake plenum. Make sure this injector is functioning correctly.
Thank you.
