Hi all!
I have a 97’ 900S with a 5-speed manual transmission. My trouble is when the car is warmed up and I try to shift into gear, the gears will grind as I put the car into first and reverse with the clutch fully depressed. All other gears go in without grinding, although I have to use a little force to get it in. Upon cold starting, the gears go in as they should; it’s only when the transmission is warmed up the gears have difficulties going into gear. My guess is the clutch needs replacing because as I release the clutch, I can feel the engine jolt a bit. Any suggestions would be great. Thanks!
