For a little wile now, I have had a growling noise when I depress the clutch pedal with the engine running. It mostly does it when the truck is cold and goes away after a few uses but was getting worse and taking longer to go away. The transmission shifts normally, the clutch operates normally and it does not make the noise if I put the transmission in neutral and let the clutch out. So I’m thinking dry throwout bearing.
I did an oil change Monday, and while it was up on the ramps, I decided to check the transmission oil level, I mean its got a 181k on it so its about time to check, right. Bone dry. I put about 2 qts of gear oil in the transmission that the service manual says has a 4 1/4 pint capacity. I took it out for a drive today and the noise is gone. Go figure.
I only drive the truck one or two times a week, sometimes less so in a couple of weeks I will check the transmission again for a leak, but there was no sign of a leak when I was under there Monday. But is still shifts smoothly, makes no noise.
