Hello All
I have a 97 Jeep Cherokee with a 4.0 V6, fuel injected, 4 wheel drive with a 5 speed. It has developed a stuttering or a hesitation at times while driving. It’s hard to describe, but feels like the engine is not getting fuel or air at short quick bursts, thus a stuttering feel.
Some things I’ve noticed:
It happens mostly when the engine is cold, but can happen any time.
It seems to be worst during rain or snow.
At low throttle, it can cause the whole vehicle to shudder violently and at full throttle (gas pedal down for acceleration) it is very noticeable but doesn’t seem to cause the vehicle to shudder as hard.
I think I hear a metallic pop or clack when it happens, especially at high throttle.
It doesn’t seem to matter what gear I’m in.
It doesn’t matter whether I’m on a flat or a hill.
It doesn’t seem to matter what speed I’m going, but it is a little harder to notice cruising along at 65.
Maintenance History: The vehicle has had several things replaced in 2011: Alternator, crank position sensor, relay on the ASD, serpentine belt, spark plugs, plug wires, cap and rotor, battery, engine compartment fan.
The vehicle went into the shop when it started dying at stop lights or stop signs and starting hard. The diagnosis was the crank position sensor and that did indeed seem to fix that problem. Within a few days, however, the vehicle started running rough and would come close to stalling when idling at a stop. My mechanic sprayed a bunch of cleaner down into the air intake part of the engine (a part that reminded me of the butterfly valve on a small carburetor). The problem went away, but this stuttering problem started up about a day later.
If anyone has any thoughts on the issue, I’d love to hear them. The vehicle is going back into the shop at the end of January to be painted and I’m going to have them drive it for a few days to see if they can isolate and fix the stuttering while it’s there. So far, they don’t have any ideas what could be causing it, but to be fair, they haven’t been able to keep the truck for a few days to drive it.
Thanks!
