94 Ford Ranger, died while driving; no spark
Thanks for catching that @ok4450.
I missed that part.
It would be wise for the OP to purchase a Hayes, or Chilton manual, so you can do this step by step.
Yosemite
Gentlemen,
I’m having the same issue with my truck the same year of pickup. I’ve replaced coil, ignition module, relays are good. It also died while driving. Is my best bet replacing the distributor? The distributor turns when I’m trying to start the truck, I’m thinking it’s the stator inside the distributor. The distributor housing was very loose when I first looked at the truck after it died. Any suggestions is the distributor the way to go? I have the pickup at a mechanics shop right now.
However, I’m still not getting spark to the coil, which tells me the issue is before the distributor. I’m going to have the mechanic try jumping the ballist resistor to see if we can get it to fire.
