1993 ford ranger 4 CLY 2 WD getting spark gas to injectors will only start when fluid is sprayed in air intake. have replaced fuel pu,p. fuel filter air intake regulator. ran okay till ran out of gas any help appreciated
What does “getting gas to injectors” mean? Have you tested the fuel pump pressure? It should be about 40 psi. Is there voltage at the injectors when attempting to start? Are you attempting to start the engine with the air intake disconnected from the throttle body?
Water in the fuel?
