Year : 1992
Make : Honda
Model : Civic VX Manual
Engine : 1.5 d15z1
Mileage : 266k
My car started to bog/dead spot/ hesitation while accelerating around 1.5k rpm to 2.5k rpm all the time in every gear but less in 4th, 5th. After 3k rpm it runs smooth. Sometimes it’s so bad that I have about 4-second dead spot while accelerating and it’s getting quite dangerous to drive around traffic
So far I have changed,
Fuel filter
Fuel pump
Spark plugs
and cleaned
injectors
intake manifold
throttle
map sensor
I have ran my car under an open loop by taking out the O2 sensor and it runs like brand new. Next thing on the list for me is to adjust the ignition timing but my question is
Since my car is running perfectly on open loop, can timing be still a factor to this problem?
