Runs/idles pretty good when cold and when warmed up at stop light it wants to die. If you put it into N or Park it idels just fine put it back into D or Reverse and you have to give it gas and brake at the same time to keep it running or it will die.
 Replaced throthle possitioning sensor 10 k ago, check engine light on code read EGR flow replaced EGR 4 k ago replaced O2 sensor 1 k ago.
 Any ideas? Please help need cube van for work.
 Dennis.
