88 chevy s10 4.3l v6
I just did TUNE UP NEW PLUGS WIRES ROTOR CAP CHECKED THE COIL AND REPLACED THE IGNITION MODULE BUT FOR SOME REASON IT WONT FIRE IT IS GETTING GAS ANYTHING
did you put a timing light on it and make sure your no. 1 tdc is set to the right angle? did you reconnected the leads in the right sequence at both ends? Have you checked for spark? Is the vacume advance working? Is it flooded with too much gas?
vacume id working,its not flooded,checked the spark its good leads r good i have not timed it
Did the truck start and run before you worked on it?
