So I’m back!
It’s still running! the big old thing. But of course, there are issues.
I was having a really hard time getting it to start. Crank after crank, there was nothing. Starter fluid, and nothing. Then I tried turning the distributor clockwise, advancing the timing I believe. Some starter fluid, and then it started. (I probably could have just pressed the gas pedal instead of using starter fluid as well.) Oh man I love that. It roared back to life.
Drove around the neighborhood for five minutes, put my foot on the brake pedal, slowed to a stop, and the engine dies. At idle, the vacuum gauge reading is usually pretty steady, though sometimes the needle fluctuates. I messed with the timing, turning the distributor here and there, trying to get the most in. Hg of vacuum, which was probably around 14-16 in. Hg.
This happened 3 times. Would drive around for 5 minutes, slow to a stop, sometimes it wouldn’t die when I would stop, but then it -would- die. Waited. Advanced the timing. Starter fluid, and it starts up again. Drive around for 5 minutes, brake occasionally without incident, then brake again, and the engine dies. 3 times this happened.
The engine seems to only start when timing is pretty advanced (turned clockwise), but when it runs, to get the highest manifold vacuum possible, I have to retard the timing, probably 1/6 of a turn counter-clockwise from where the engine seems to like the timing to be, in order to start. I hope that isn’t confusing. In other words, I think for the best chance of the engine to start, I have the timing advanced. But once it starts, to get the most vacuum, I have to retard, manually, by turning. I know this shouldn’t be. I have no idea what I’m doing. I’m clueless.
Then a new problem I hadn’t faced before. Sometimes the starter won’t even crank, and there’s this electronic buzzing beeping noise. I felt the nut on the starter, and it was very hot. I think maybe that’s just an over-heating safety thing or something. Waited a few minutes, and it would crank again.
Another thing I did to try and get maximum vacuum, is that there are two idle mixture screws on the 2 back corners of the carburetor. 1 of the screws doesn’t seem to affect vacuum or idle or anything so much really. The other screw, if I screw in too much, the engine will sputter and almost die and vacuum would decrease. I unscrewed it pretty much all the way, and vacuum increased.
The other 2 screws on the throttle or whatever it is, the thing that moves when I hit the gas pedal, are both turned all the way in. When I unscrew the top one, it closes the throttle plate, and the engine wants to die, and vacuum decreases. I just screwed it all the way in, and then vacuum is as good as it gets. I mean if I really wanted high vacuum, like 20 in. Hg, I could tape the choke plate.
I might as well admit this shameful detail. Which goes to show, I have absolutely no business messing with a carburetor, and I should seek help from a professional. And I most likely will, after hearing what you fine folks have to say. I am wondering how much it might cost to have a carburetor and the timing adjusting, if it is just those issues. Most shops charge like $100 an hour. I bet a mechanic looking for side work would charge around $70 or something. Shouldn’t take more than hour to adjust, right?
But here goes - I did do that, lol, and it was shameful and it was horrible. Because what was happening before was that the engine would die whenever I would put it into drive. Just not enough juice - not enough air/fuel/vacuum/timing was off, or something. It would just stall out. But when I would tape the choke plate in a way that vacuum would roar to 21 in. Hg, when I put it into drive, it wouldn’t die, (but the entire engine would violently jerk with the force of an atom bomb into drive!) and I could drive it. But man oh man, with my foot completely off the pedal, I could get upwards of 30 mph, heh. And well, that shouldn’t be. Foot off the pedal, car should go like 5mph, right? Well that piece of tape led to 2 broken motor mounts, and DAYS of agony and pain and an incident with a torch that caught a piece of the RV on fire in which I had to use a fire extinguisher which at least I had the foresight to have next to the torch. Learned a lot of lessons. But anyway, let’s move on and never speak of this again.
In hindsight, I think it was timing all along. I did replace the intake manifold gasket, and maybe there was a leak and maybe replacing this is why the RV can run now without dying when put into gear, but I think it’s the timing. And maybe the stupid stupid carburetor. Never again. It’s sick, because a part of me hates carburetors, but I have had so much fun with this miserable thing, and I love seeing and hearing that carburetor roar. But the heart is deceitful above all things, and desperately wicked, and logic and reason must bear sway. So never again carburetors! Never again!
TL;DR, in summary - The engine seems to only want to start (maybe, I don’t know, lol) when the timing is advanced, and the best vacuum seems to be when it is retarded from that advanced point, but I know I shouldn’t need to manually adjust timing while driving, lol. Also, the engine is dying after driving for five minutes, when I hit the brake. And occasionally the engine seems like it’s misfiring, or the vacuum gauge needle fluctuates, but then other times with messing with the timing, it runs really smooth with no jerkiness, and the vacuum gauge is really steady. Sometimes it’s at a good strong steady 16 in. Hg, other times closer to 14, I don’t even really know or remember. I’m just confused and clueless. Should I just pay to have a professional look at it, lol. A long time ago, when I knew nothing about cars, I paid a mechanic a hundred dollars to add water to my battery, and then it started. Lol. Anyway, any advice is appreciated, thanks.
