Hey folks - I have a 2000 GMC Safari, my second such Astro/Safari beast, and have just noticed the beginnings of a tranny hick-up. I have 100,000mi on it, and just returned from a 500mi day trip in 95 degree weather. After several hours highway driving, I pulled away from a stop light she banged into 2nd gear a bit. My last Astro had the same problem, except it wouldn’t take near as much heat build-up, and once hot, the 1-2 shift would feel like the rear end was falling out. After some research, I have found that this is a common problem, and relates to torque converter overheating and premature tcc valve wear. The solution is replacing the valve, and installing a shift kit (I’m looking at a Transgo product). My question is, can I easily enough remove and reinstall the valve body without pulling the tranny, and for those who have done the job, what kind of special tools I may need. Thanks!
Related topics
| 1998 Ford Ranger - Trans issue | 34 | 809 | January 23, 2026 | |
| Tranny? | 1 | 404 | October 6, 2009 | |
| Transmission swap in a 2006 gmc sierra....HELP! | 3 | 2701 | November 9, 2011 | |
| GM Sierra Auto Tranny Pop and Scream | 3 | 633 | October 19, 2009 | |
| Time for a tranny? | 8 | 1047 | March 7, 2011 |
