4 wheel drive switch problem
Hello,
I own a 2006 Ford F-150. I have a problem with the 4 wheel drive switch. It wont work! A light will go on when it is turned on and you can feel it when it engages. Nether of these two happen. I looked at the fuse box, but it is unclear to me which one it is. Even when looking at the owners manual. Do you think it is a bigger problem then electrical? what should I do?
Also so can you estimate the coast of repair? Wether it be electrical or something more series.
Too complicated for this post.
See owner’s manual again. I see 4x4 related fuses and relays in 5 different locations.
The switch is only part of the chain of command for 4x4. There’s also the shift motor on the t/c, the main computer, and the wires & plugs.
ok. thanks. think I will just take it to the shop. was hoping for a quick fix
