this engine is in a 1989 trams am turned port injection the four injectors on the driver side of the car will not fire a noid light. have installed a rebuilt computer with new prom checked all wiring still have same problems . the car does have a e.s.c on the fire wall but all plugs fire. has a new distributor. done all that i can think of sure do need some help. the only code that the computer will store is the t.p.s installed a new one with no help.still the same problem do not know what to do to fix the problem with this car. thanks larry
The injectors should receive power through a pair of fuses; one fuse for each set of 4 injectors. Odds are the fuse is blown. Hope that helps.
