2022 Jeep Wrangler - Two warning lights
2022 Jeep Wrangler, JL has ABS and Traction control warnings on, won’t shut off. Car is new and never been off road, steering straight, cruise works. Tried reset computer still came back.
\\\Use the WARRANTY/////
Advice above spot on, don’t try to fix yourself, ask dealership. Fixing it yourself might be possible, but might also void warranty.
If your query is simply what are the sort of likely causes, anything adversely effecting engine or transmission performance could turn that warning light on. While possible, the problem is not likely to be problematic ABS or traction control systems. The issue: Those systems won’t work properly, could be unsafe, if engine or transmission is not performing as designed; so manufacturer’s software turns those systems off if computer detects problem that could effect engine or transmission performance.
Your dealership will probably start by a visual once over. Maybe a connector is loose. After that by reading the drivetrain’s computer diagnostic codes with their pro scan tool. If that doesn’t explain the warning, then they will read the ABS and traction control computer diagnostic codes.
Agree with Renegade bring it to the dealer.
there is a software update for the ABS and probably one for the traction control. or the update might fix both.
TSB 08-136-18 Flash: AntiLock Brake System (ABS) Module Diagnostic and System Updates - Oct 16, 2018 | Jeep Wrangler Forums (JL / JLU) - Rubicon, Sahara, Sport, 4xe, 392 - JLwranglerforums.com
ITS A JEEP THING :wink: :rofl:
