The same with my '96 ES300 - identical V6 as in the Camry. But surprisingly, they ‘recommended’ premium fuel, while the Camry recommended regular. I tried both, saw no difference in power or economy, so I used regular. No problems in 15 years.
I checked fuel economy.gov, and they have identical gas mileage estimates for the ES300 and Camry using regular. No high test listed. I only mention this because Lexus recommended high test in the owner’s manual in 1996. I imagine that the recommendation was revised since then. The EPA/DoE don’t recommend fuel, but use auto manufacturer recommendations.
Yeah, “recommended” is usually a sign that the engine will retard the timing if you use regular, which will cut power a little but not hurt anything. Makes me wonder if they have a different distributor/ecu setup in the Lexus version, or if they just assumed Camry drivers are too boring to care about more power. ![]()
They’re no longer doing that. Mine just says use 87 octane.
