2020 3L. Duramax timing chain replace after ~ 60k
@bcohen2010
With all due respect, I partially disagree with you
Please explain how arthritis is due to unsafe work practices and not using PPE
My cousin’s husband repaired and calibrated lab equipment for a major manufacturer. He had his equipment in a couple of steamer trunks, and they were very heavy, but he carried them anyway. He developed a bad back and later in life was in constant, debilitating pain, even with pain killers. Late in his career he used hand trucks to move his equipment, but it was too late then.
Arthritis is often due to repetitive movements over the course of a career, afaik
Don’t see how you can necessarily attribute that to unsafe work practices and not using PPE, @bcohen2010
There are numerous causes of arthritis, some disease based and some injury or repetitive stress. The latter two could be considered under the common umbrella of ES&H in the workplace. Specifically, ergonomics playing a role in repetitive stress and/or injury. An example of this might be working/bending over a tall vehicle engine bay day after day and lifting heavy objects in/out. The company could invest in means to reduce this stress and prevent workplace injuries resulting from this environment. More often, they simply ignore it because they have a seemingly unending supply of freshly minted resources to draw from. The hidden cost is in the training and expertise built up over years that is lost when a more senior team member is injured and can no longer perform their job function effectively due to long term exposure to these hazards…
Yes it is Off Topic, happens a lot. But why the rest of that ?
Because one of you folks flagged a perfectly fine post in relation to th3bither posts and it was removed. Cant even see it myself to know how jt offended you.
