drivers side lower console area, draft of cold,when air heating controls set, @max temp, max fan speed, fresh air mode!
You’ll need to take this in, it’s under warranty, see if some setting is off. Have you selected ‘auto’ and a high temperature? Or are you changing other settings? Try using ‘auto’ and adjusting the temp.
