How to check, Transmission level on my car, is there a site glass on which side of Transmission, temperature level at 170-200, thankyou very much.
Why do you need to check the level on a 2019 vehicle . And no there is not a sight glass .
There is a service procedure to check the transmission fluid level on modern vehicles. In general, with the fluid at a specific temperature a service plug is removed to verify the fluid level. Checking the ATF level on a frequent bases is unnecessary.
