Temperature Guage doesn’t work, fan on motor runs, air conditioner doesn’t work when this happens and message says, “steering assist reduced, drive with caution.” Replaced temperature coolant sensor, still having problem.
This could be a possible cause for your vehicles problem…
I had the exact same problem (all issues). Ultimately it my thermostat was physically broken. Replacing that solved the issue.
