vibration is felt @1200-1800 RPM in any gear when under slight load or compression
it should still be under warranty. bring it to the dealer.
Thanks! have appt. already. The dealer tried to pass off vibes as tire balance but I found it is directly RPM/load related regardless to speed/gear and occurs 1250-1750. I found similar complaints in Audi site attributed to harmonics/mounts.
