2018 Kia Sorento - Turn signal messes up lights
when driving at night and using turn signal, the lights will go off. I have to jiggle the turn signal to get them back on. However, the other night, no turn signal used and lights went off. I had to turn lights on and off to get them working again. This was random, but now happening more often.
Looks like you found the problem. And the big “clues” for the solution.
If turn signal set by same lever as headlights on/off, that’s same config as my Corolla, and pretty good chance that entire ass’y needs replacing. Not an uncommon problem reported here. On my Corolla requires removing steering wheel, not a simple diy’er job.
